*plyrealization_option
Extracts/projects elements belonging to ply contours.
*plyrealization_option ply_mark_id entity_type mark_id project x1 y1 z1 x2 y2 z2 reserved1 search_option reserved2 shrinkage table_id double_array number_of_doubles reserved3 reserved4
HyperMesh Tcl Modify Command
- ply_mark_id
- The ID of the mark containing the input plies. Valid values are 1 and 2.
- entity_type
- The type of entity to use to extract/project the plies. Valid values are comps and elems.
- mark_id
- The ID of the mark containing the entities to extract/project. Valid values are 1 and 2.
- project
- 0 - Project normal to the contour plane
- 1 - Project normal to the mesh
- 2 - Project along an arbitrary direction using the x1, y1, z1 and x2, y2, z2 arguments.
- 3 - Drape map by proximity method (FiberSIM/CATIA composite link)
- x1
- The x coordinate of the direction base. Only used if project is set to 2.
- y1
- The y coordinate of the direction base. Only used if project is set to 2.
- z1
- The z coordinate of the direction base. Only used if project is set to 2.
- x2
- The x coordinate of the direction normal. Only used if project is set to 2.
- y2
- The y coordinate of the direction normal. Only used if project is set to 2.
- z2
- The z coordinate of the direction normal. Only used if project is set to 2.
- reserved1
- Reserved for future use. Must be set to 0.
- search_option
- Use the specified search criterion as:
- 0 - Centroid
- 1 - All nodes inside
- 2 - Shrinkage factor of border element edges
- reserved2
- shrinkage
- The shrinkage area factor. Only used if search_option is set to 2.
- table_id
- The ID of the table that holds core sample data. The table consists of 2 columns, "ply" and "points" that contain ply names and sampling points, of data type string and triples, respectively.
- double_array
- The ID of the double array that contains the x, y and z coordinates of sample points. The double array is created using the *createdoublearray command. This should always be set to 1.
- number_of_doubles
- Integer indicating the size (number of doubles) in the double array created using *createdoublearray.
- reserved3
- reserved4
Examples
*createmark plies 1 "Ply3"
*createmark elems 1 1-10
*plyrealization_option 1 elems 1 1 0 0 0 0 0 0 0 1 0 0 0 0 0 0 0*createmark plies 1 "Ply3"
*createmark elems 1 all
*plyrealization_option 1 elems 1 1 0 0 0 0 0 0 0 2 0 0.25 0 0 0 0 0- Create a table to store core sample data, using ply names Ply1 and Ply2 and sample
points (1.1, 2.1, 3.1) and (4.1, 5.1,
6.1):
*createstringarray 2 "string" "triple" *tablecreate "coresample_table" 1 1 1 2 0 *createstringarray 2 "Ply1" "Ply2" *tableinsertcolumn "coresample_table" "string" "ply" 1 2 1 *createstringarray 6 "1.1" "2.1" "3.1" "4.1" "5.1" "6.1" *tableinsertcolumn "coresample_table" "triple" "points" 1 6 2 - Ply realization, assuming the table ID of coresample_table is
2:
*createmark plies 1 "Ply2" *createmark elems 1 1-10 *plyrealization_option 1 elements 1 1 0 0 0 0 0 0 0 0 0 0 2 0 0 0 0
# Handle error
}Version History
12.0.110
