*splitsolidelements
Divides the given solid elements into hexa or tetra elements.
*splitsolidelements markmask splittype
HyperMesh Tcl Modify Command
- markmask
- The mark of solid elements to be split.
- splittype
- A code that indicates the type of split to perform.
- 1 - splits a hexa into 8 hexas
- 2 - splits a hexa into 5 or 6 tetras
- 3 - splits a hexa into 24 tetras
*createmark elements 1 100 101 102 103 104 105 106 107 108
109 110
*splitsolidelements 1 1 The *createmark() directive is required for this command.
None.
