*morphsplitmorphvolumes
Splits the morph volumes in the model given the specified morph volume edge.
*morphsplitmorphvolumes n1 n2 split hand tangent
HyperMesh Tcl Modify Command
n1
ID of first end node of morph volume edge.
n2
ID of second end node of morph volume edge.
split
If > 1.0: number of splits
If < 1.0: position along edge for split
hand
0 = do not create handles for morph volumes
1 = create handles for morph volumes
tangent
0 = no tangency
1 = make neighboring morph volume edges continuously tangent.
*morphsplitmorphvolumes 21 22 2.0 1 1
This command will propagate one or more splits along the specified morph volume edge through the entire morph volume "matrix" so that it remains consistent.
Newly formed morph volumes can optionally have handles and tangency automatically applied.
The higher the value of 'split' (if less than 1.0), the closer to n2 the split will occur.
None.
