*rigidlink
Creates a rigid link element between an independent node and multiple dependent nodes.
*rigidlink independent mark dofs
HyperMesh Tcl Modify Command
independent
The independent node of the element.
mark
The ID of the mark containing the dependent nodes.
dof
The degree of freedom code for which all of nodes of the element are active (any of the digits 1-`6).
To create a rigid link element with independent node 100 and dependent nodes 101, 102, and 103 with nodes having all six degrees of freedom:
*createmark nodes 2 101 102 103
*rigidlink 100 2 123456
A *createmark() command is required to define the mark.
None.
