*elementqualitysetup
Prepares a mark of elements for use within the interactive element cleanup tool.
*elementqualitysetup elementmark
HyperMesh Tcl Modify Command
elementmark
The mark ID containing the elements to be modified.
*createmark elements 1 10 11 12 13 14 15 16
*elementqualitysetup 1
<<various *elementquality commands>>
*elementqualityshutdown 0
This function interacts closely with the other *elementquality() commands, and cannot function separately from them. It must be accompanied by a corresponding *elementqualityshutdown() command.
