*createelementsbetweenpoints
Creates a spotweld element between two surfaces at the marked points with an element type, coordinate system, and property ID.
*createelementsbetweenpoints surf1_markmask surf2_markmask markmask tol createplot configval syst code ?property?
HyperMesh Tcl Modify Command
- surf1_markmask
- First or multiple surfaces in the mark.
- surf2_markmask
- Second surface in the mark, if given.
- markmask
- Marked points.
- tol
- Search tolerance to identify surfaces.
- createplot
- Creates a plot.
- configval
- Element type configuration value.
- syst
- Local coordinate system switch.
- 0 - Without coordinate system.
- 1 - With coordinate system.
- code
- Code for one or all surface options.
- 0 - All surfaces.
- 1 - One surface.
- ?property?
- Name of property collector. Retrieves property ID.
Examples
*createelementsbetweenpoints 1 2 2 0.01 1 21 1 1 "name_prop"
