*facepreviewduplicates
Finds duplicate faces.
*facepreviewduplicates mark tol
HyperMesh Tcl Modify Command
mark
The mark ID which contains the faces to compare for and delete duplicates.
tol
The tolerance used to find duplicate faces.
To find duplicates within a tolerance of 0.1, among the faces 2, 4, 7, 14, and 23:
*createmark faces 1 2 4 7 14 23
*facepreviewduplicates 1 0.1
This command removes any non-duplicate faces from the mark. The *createmark() command is required.
