*graphimport_file
Imports a mesh stored in HDF5 into the graphics.
*graphimport_file filename
HyperMesh Tcl Modify Command
- filename
- The full path and filename of the HDF5 mesh file.
Examples
*graphimport_file "C:/temp/mesh.hmg" Errors
# Handle error
}Version History
2019
