*surfacesplitwithsurface
Splits one surface with another.
*surfacesplitwithsurface surface1 surface2
HyperMesh Tcl Modify Command
- surface1
- The surface to be split.
- surface2
- The surface used to split surface1.
*surfacesplitwithsurface 1 2 Errors
None.
