*surfacespherefromthreepoints
Creates a full or partial sphere, and optionally, prepares it for immediate use within the automesher. It can also identify a region in the shape of such a sphere for the automesher to use under the mesh without surface option.
*surfacespherefromthreepoints center_node radius r_node theta_start theta_end angle_node phi_start phi_end angle_type
HyperMesh Tcl Modify Command
- center_node
- A node specifying the center.
- radius
- The radius of the sphere.
- r_node
- A node specifying the r vector.
- theta_start
- Angle at which theta starts (0.0 to < theta end).
- theta_end
- Angle at which theta ends (> theta start to 360.0).
- angle_node
- A node specifying the angle vector.
- phi_start
- Angle at which phi starts (-90.0 to < phi end).
- phi_end
- Angle at which phi ends (> phi start to 90.0).
- angle_type
- Defines whether the angle vector is to be theta or phi.
To create one quarter of a sphere with a radius of 10 through using nodes 1, 2 and 3, but not create any elements:
*surfacemode 4
*surfacespherefromthreepoints 1 10.0 2 0.0 180.0 3 0.0 90.00 0
The *surfacemode(4) directive tells HyperMesh not to pass the information on to the automesher for element creation.
None.
