*morphmaptshp
Adds a handle perturbation to the current temporary shape.
*morphmaptshp hptr x y z clear sym con
HyperMesh Tcl Modify Command
hptr
ID of handle.
x
x perturbation of handle
y
y perturbation of handle
z
z perturbation of handle
clear
0 - Add perturbation
1- Clear temporary shape and add perturbation
2 - Unapply temporary shape
sym
0 - Do not use symmetry (only option)
con
1 - Use constraints (only option)
*morphmaptshp 21 1.0 2.0 3.0 0 0 1
This command is part of the map to geometry function which consists of multiple commands. This command is called any number of times, first with clear set to 1, then subsequently set to 0, followed either by one of the many *morphmapto…() commands. If clear is set to 2 then the last *morphmaptshp() command is rejected.
   # Handle error
