*nodecloud2facet
Generate STL facets from a node cloud.
*nodecloud2facet entity_type mark_id reserved param_string
HyperMesh Tcl Modify Command
- entity_type
- The type of input entity. Must be set to nodes.
- mark_id
- The ID of the mark containing the input entities. Valid values are 1 and 2.
- reserved
- Reserved for future use. Must be set to 5.
- param_string
- A string containing extra parameters in the following format: "scanradius <radius>;fillholesize <size>"
Examples
*createmark nodes 1 all
*nodecloud2facet nodes 1 5 "scanradius 4;fillholesize 10"Errors
# Handle error
}Version History
2020
