*linesplitatjoint
Splits a line at a joint.
*linesplitatjoint line node
HyperMesh Tcl Modify Command
line
The line which should be split.
node
The node which represents a position close to the joint where the line should be split.
To split line 10 at node 3:
*linesplitatjoint 10 3
None.
