*morphupdateendcondition
Updates the end condition of one or two morph volume edges.
*morphupdateendcondition n1 n2 n3 x y z mode
HyperMesh Tcl Modify Command
n1
Node at end of first edge.
n2
Node between first edge and second edge.
n3
Node at end of second edge (if necessary).
x
X component of vector for end direction
y
Y component of vector for end direction
z
Z component of vector for end direction
mode
0 - free
1 - set to vector
2 - main-secondary tangency
3 - secondary-main tangency
4 - continuous tangency
*morphupdateendcondition 21 22 23 1.0 0.0 0.0 1
This command either frees the specified edge end, sets the direction of the edge end equal to the given vector, or enforces a tangency condition between two edges. The end of an edge which is affected by this command is marked by n1.
None.
