*morphupdatedisplay
Updates the display of morphing entities.
*morphupdatedisplay type mode
HyperMesh Tcl Modify Command
type
0 = all morphing entities
1 = global handles and domains
2 = local handles and domains
3 = morphvolumes
4 = morphconstraints
5 = symmetries
6 = shapes
mode
0 = turn off
1 = turn on
2 = turn on only for entities on displayed elements
*morphupdatedisplay 0 0
Note that if the type is set to zero (all morphing entities) the mode will be the same for all types.
None.
