*updatepropertyidforfejoints
Updates the property ID for the given FE joint elements.
*updatepropertyidforfejoints mark_id property_id
HyperMesh Tcl Modify Command
- mark_id
- The ID of the mark containing the joint elements to update.
- property_id
- The ID of the PJOINTG property.
Examples
To update joint elements 9 and 10 with property ID 2:
*createmark elements 1 9 10
*updatepropertyidforfejoints 1 2
# Handle error
Version History
2019
