*linecreatefromcoords
Create a line passing through a list of 3D points.
*linecreatefromcoords type break_angle aspect linear_angle double_array number_of_doubles
HyperMesh Tcl Modify Command
- type
- The type of line to generate. Valid values are:
- break_angle
- Specifies the minimum angle allowed between three points in a line. If the angle between a point and the two adjacent points is less than the angle specified, this point is considered to be a point of discontinuity in the line and a joint is placed (the start of a new NURBS) at this location.
- aspect
- Specifies the maximum ratio allowed for the distance between a point and the previous point in the line and the distance between the same point and the next point in the line. If the ratio of the distance between the two adjacent segments exceeds the aspect ratio defined, a joint is placed between the segments.
- linear_angle
- Defines the angle at which the line is considered a straight line. For example, if the line angle between three consecutive points along the line is greater than the linear angle specified, the center point is removed from the line.
- double_array
- The ID of the double array that contains the values. The double array is created using the *createdoublearray command. This should always be set to 1
- number_of_doubles
- Integer indicating the size (number of doubles) in the array created using *createdoublearray.
Examples
*createdoublearray 9 -2.50392465 6.43642072 0 1.04395604 5.9811617 0 4.56043956 5.71428571 0
*linecreatefromcoords 0 150 5 179 1 9Errors
# Handle error
}Version History
2020
