*surfacemarksplitwithplane
Splits a group of surfaces with an infinite plane.
*surfacemarksplitwithplane mark plane
HyperMesh Tcl Modify Command
- mark
- The ID of the mark containing the surfaces.
- plane
- The plane used to split the surfaces.
To split surfaces 10 and 20 with the xy plane (normal equals the z-axis):
*createmark surfaces 1 10 20
*createplane 1 0.0000 0.0000 1.0000 0.0000 0.0000 0.0000
*surfacemarksplitwithplane 1 1
None.
