*createinclude
Defines a new include file in the database.
*createinclude id shortname fullname parentid
HyperMesh Tcl Modify Command
id
Use 0, if HyperMesh should take the next available ID. Specifying a non-zero value will overwrite any existing include that already uses that ID value.
shortname
The last portion of the fullname (not including path). Short names must be unique.
fullname
The include’s full name, including file path. Must be unique, and must conform to the shortname, as described above.
parentid
The identifier for the file that includes this file.
0 - Means the new file is included by the main file.
Non-unique shortnames or fullnames produce errors.
Examples
To create a new include called mat1.dyn, using the main file as its parent:
*createinclude 0 mat1.dyn "C:/common files/mats/mat1.dyn" 0
