*morphsurfaces
Calls surface morphing function.
*morphsurfaces surftype marksurf
HyperMesh Tcl Modify Command
- surftype
- Surfs
- marksurf
- Surface mark number
*morphsurfaces SURFS 1
This command morphs the surfaces for a given model. Any surface that is associated with a node that has been morphed will be morphed when this command is used.
None.
