*xyplotregisterexternalreader
Registers a translator for use in the Edit Curves panel.
*xyplotregisterexternalreader path
HyperMesh Tcl Modify Command
path
Path of the executable for the reader.
*xyplotregisterexternalreader daisy.exe
With external readers, you can expand the file reading capabilities of the Edit Curves panel through the addition of custom readers. Custom readers can be written in C or Fortran.
None.
