*reflectmark
Reflects a selection of entities about a plane.
*reflectmark entity_type mark_id plane_id
HyperMesh Tcl Modify Command
This command reflects a selection of entities about a plane.
- entity_type
- Type of entity to reflect.
- mark_id
- The ID of the mark containing the entities. Valid values are 1 and 2.
- plane_id
- The ID of the plane to use for the reflection. This is defined using the *createplane command.
*createplane 1 1.0 0.0 0.0 0.0 0.0 0.0
*createmark elems 1 15
*reflectmark elems 1 1Errors
# Handle error
