*xelem_bysetid
Creates a new element (/XELEM) of config 27 and type 1 using a node set.
*xelem_bysetid node_set_id
HyperMesh Tcl Modify Command
Creates a new element (/XELEM) of config 27 and type 1 using a node list. This is currently only supported for Radioss.
- node_set_id
- The ID of the node set to create the element from. The set must be an ordered node set of type /GRNOD/NODENS, and must contain at least two nodes.
Examples
Create an /XELEM element with ordered node set of ID 5:
*xelem_bysetid 5
# Handle error
}Version History
2019
