*solidmesh12lines
Creates a solid mesh in a volume formed by twelve lines.
*solidmesh12lines lines density1 density2 density3
HyperMesh Tcl Modify Command
- lines
- The line list ID which contains lines that define a solid.
- density1
- The density of the elements in the first direction.
- density2
- The density of the elements in the second direction.
- density3
- The density of the elements in the third direction.
None.
