*linesplitatpoint
Splits a line at an arbitrary point.
*linesplitatpoint line node
HyperMesh Tcl Modify Command
line
The line to be split.
node
A node which represents the location on the line where it should be split.
To split line 10 at node 3:
*linesplitatpoint 10 3
None.
