*voxel_lattice_hex_mesh_remove_volume
Removes a volume surrounding a given point from the voxel domain.
*voxel_lattice_hex_mesh_remove_volume x y z
HyperMesh Tcl Modify Command
Removes a volume surrounding a given point from the voxel domain. The volume is determined by the elements that are part of the domain when this command is run.
This must be preceded by a call to *voxel_lattice_hex_mesh_init and must be followed by a call to *voxel_lattice_hex_mesh_create.
- x
- The x-coordinate of the point inside the volume.
- y
- The y-coordinate of the point inside the volume.
- z
- The z-coordinate of the point inside the volume.
To create voxels of size 10 for include components 100-110, and removing the volume surrounding (50,50,50):
*voxel_lattice_hex_mesh_init 10
*createmark comps 1 100-110
*voxel_lattice_hex_mesh_add_entities comps 1 1
*voxel_lattice_hex_mesh_remove_volume 50 50 50
*voxel_lattice_hex_mesh end
# Handle error
}Version History
2019.1
