*assignsystem_option
References a coordinate system to an element.
*assignsystem_option entity_type mark_id system_id axis only_orient normal_size color option
HyperMesh Tcl Modify Command
References a coordinate system to an element. The specified axis of this system is then projected on the element plane. Re-orients and visualizes the element (material) coordinate system for selected elements. When review is complete, the command *vectorsoff must be run.
- entity_type
- The type of entity to update. Only elements are supported.
- mark_id
- The ID of the mark containing the entities. Valid values are 1 and 2.
- system_id
- The ID of the system to project onto the element plane. A value of 0 indicates the global axes.
- axis
- Determines the selected axis of the coordinate system to be projected. This axis is projected onto the element plane to define the element orientation. Angle theta is determined from the new x-element direction and the element normal, and then saved. The new x-element direction is visualized.
- only_orient
- 0 - The new x-element directions are shown as continuous gradient lines starting and ending on free edges.
- normal_size
- If only_orient =1, this defines the size of the displayed vectors.
- color
- The color of the vectors or lines. Valid values are 1 through 64.
- option
- Option for review customization. Valid values are:
Examples
To project the z-axis of the global coordinate system (ID = 0) on the element plane of four selected elements and display the projection as blue vectors (color 7) with size = 3:
*createmark elems 1 376 377 389 418
*assignsystem_option elems 1 0 2 1 5 7 1
*vectorsoff
*assignsystem_option elems 1 1 -1 0 0 10 1
*vectorsoffErrors
# Handle error
}Version History
11.0.101
