*attributeupdatestringarrayelementmark
Updates one element of an attribute of type string array.
*attributeupdatestringarrayelementmark entity_type mark identifier solver status behavior index value
HyperMesh Tcl Modify Command
- entity_type
- The type of entity that owns the attribute.
- mark
- The number of the mark.
- identifier
- The identifier of the attribute.
- solver
- The solver number of the attribute.
- status
- The status of the attribute.
- behavior
- The behavior of the attribute.
- index
- Index into the array (first index is zero).
- value
- The value of the array element.
Examples
*createmark materials 1 7 8
*attributeupdatestringarrayelementmark materials 1 615 2 2 0 0 "steel"
