*rigidwall_geometry
Adds geometric definition to a rigid wall.
*rigidwall_geometry name geometrytype basenode vectors n1 n2 geomvar1 geomvar2 geomvar3
HyperMesh Tcl Modify Command
- name
- The name of the rigid wall.
- geometrytype
- Use:
- 1 infinite plane
- 2 finite plane
- 3 infinite prism
- 4 finite prism
- 5 cylinder
- 6 sphere
- basenode
- The ID of the base node for the rigid wall.
- vectors
- The normal vector.
- n1, n2
- The ID of the nodes used to define the rigid wall.
- geomvar1
- The length in the x direction or radius.
- geomvar2
- The length in the y direction.
- geomvar3
- The length in the z direction.
None.
