*attributeupdatedoublearray2dmark
Updates an attribute of type 2D double array on a set of entities.
*attributeupdatedoublearray2dmark entity_type mark identifier solver status behavior data rows cols
HyperMesh Tcl Modify Command
- entity_type
- The type of entity that owns the attribute.
- mark
- The number of the mark.
- identifier
- The identifier of the attribute.
- solver
- The solver number of the attribute.
- status
- The status of the attribute.
- behavior
- The behavior of the attribute.
- data
- 2D array of doubles.
- rows
- The number of rows in the array.
- cols
- The number of columns in the array.
Update an attribute of type 2D double array to [1,2,3] on materials with IDs 7 and 8.
*createmark materials 1 7 8
*createdoublearray2d 2 3 1 2 3 5 6 7
*attributeupdatedoublearray2dmark materials 1 615 2 2 0 1 1
