*mbplanecreate
Creates a new mbplane entity.
*mbplanecreate name color type origin xaxis yaxis multibodyid
HyperMesh Tcl Modify Command
- name
- The name of the mbplane.
- color
- The color value of the mbplane.
- type
- The type definition to be used later.
- origin
- The center node for the mbplane.
- xaxis
- The xaxis node for the mbplane.
- yaxis
- The yaxis node for the mbplane.
- multibodyid
- The ID of the multibody to which the mbplane is attached.
None.
