*elementqualityshutdown
Closes down a session of the interactive element cleanup tool.
*elementqualityshutdown dontsaveflag
HyperMesh Tcl Modify Command
dontsaveflag
A nonzero value tells the system that it should not transfer your changes from within the element cleanup tool to the permanent database.
*createmark elements 1 10 11 12 13 14 15 16
*elementqualitysetup 1
<<various *elementquality commands>>
*elementqualityshutdown 0
