*attributeupdate_entityidarray2d_mark
Updates an attribute, which is a 2D array of entity IDs, on a set of entities.
*attributeupdate_entityidarray2d_mark entity_type mark identifier solver status behavior target entity data rows cols
HyperMesh Tcl Modify Command
- entity_type
- The type of entity that owns the attribute.
- mark
- The number of the mark where the list of IDs resides.
- identifier
- The identifier of the attribute.
- solver
- The solver number of the attribute.
- status
- The status of the attribute.
- behavior
- The behavior of the attribute.
- target entity
- The type of entity to which the attribute refers.
- data
- The 2D array of IDs.
- rows
- The number of rows in the array.
- cols
- The number of columns in the array.
- 1 2
- 8 9
*createmark loadcols 1 1 2 3 4 5 6 7
*createarray 4 1 2 8 9
*attributeupdate_entityidarray2d loadcols 1 1234 1 2 0 materials 2 2
