*visualizemode
Sets the parameters for visualization mode.
*visualizemode hiddenline fillmode meshmode plot
HyperMesh Tcl Modify Command
- hiddenline
- Set to 1 for hidden line, 0 for wire frame.
- fillmode
- Set to -2 for contours, -1 for element color, or 0-15 for constant color.
- meshmode
- plot
- Set to 1 to re-plot the screen after this command is executed, otherwise set to 0.
This command is valid only after the system has entered into visualization mode.
None.
