*xyplotcoloroverride
Sets the override color for xy plots.
*xyplotcoloroverride color
HyperMesh Tcl Modify Command
- color
- Set to the color which should be used to plot all of the xy plot information on the screen (1-15).
If the color is set with this command, all of the entities on an xy plot are plotted in that color. If color is set to zero, the color of each of the entities on the xy plot is used.
None.
