*morphrenamehandle
Renames a handle.
*morphrenamehandle nameold namenew
HyperMesh Tcl Modify Command
Renames a handle.
nameold
Current name of handle.
namenew
New name of handle.
*morphrenamehandle "bob" "dave"
Name of handle is changed from nameold to namenew.
The new name does not need to be unique since this command will create a unique name if a duplicate is detected.
This command is not called in HyperMesh. The general rename command is used instead.
None.
