*linescombine
Combines two free surface edges to create one unsuppressed common edge.
*linescombine edge1 edge2 edge_tolerance
HyperMesh Tcl Modify Command
edge1, edge2
Two free surface edges (face edges which are attached to a surface only once).
edge_tolerance
The edges must be within this tolerance.
To combine edges 101 and 39, using a tolerance of 0.1:
*linescombine 101 39 0.1
None.
