*shapevarupdate_xproduct
Updates a shape variable created from the cross product of two other shape variables.
*shapevarupdate_xproduct markid basenode shape_variable_A shape_variable_B baseflag directionflag magnitude
HyperMesh Tcl Modify Command
- markid
- The ID of the mark that contains the shape variable to update.
- basenode
- The ID of the node where the base of the result is located after it is updated.
- shape_variable_A
- The ID of the first shape variable in the cross product.
- shape_variable_B
- The ID of the 2nd shape variable in the cross product.
- baseflag
- A flag (0,1) to update the base node of the shape variable.
- directionflag
- A flag (0,1) to update the direction and magnitude of the shape variable.
- magnitude
- Magnitude of vectors.
None.
