*hf_Create_DieCadSys
Creates a system from the CAD system stored in the database.
*hf_Create_DieCadSys reserved
HyperMesh Tcl Modify Command
This command creates a system from the CAD system stored in the database.
- reserved
- Reserved for future use. Must be set to 0.
*hf_Create_DieCadSys 0
# Handle error
Version History
11.0
