*refineelementsbydeviation
Refine elements to chordal deviation.
*refineelementsbydeviation mark deviation minlength
HyperMesh Tcl Modify Command
mark
The ID of the mark which contains the elements to be refined.
deviation
The maximum chordal deviation.
minlength
The minimum element edge size.
To refine the elements to chordal deviation:
*createmark elements 1 86 88 113
*refineelementsbydeviation 1 0.01 0.1
*createmark() is required.
None.
