*elementtestdependancy
Tests 1D weld and rigid elements for double dependencies and puts those that fail on the specified outputmark.
*elementtestdependancy entities markmask outputmark
HyperMesh Tcl Modify Command
entities
The entity types to be checked. Currently, elements is the only allowable option.
markmask
The mark that contains the elements to test.
outputmark
The mark where HyperMesh should put the elements that fail the test.
*createmark elements 1 "displayed"
*createmark elements 2
*elementtestdependancy elements 1 2
