*morphdoshape
Apply undo, redo, undo all, or redo all.
*morphdoshape option
HyperMesh Tcl Modify Command
- option
- 1 - Undo most recent morph
*morphdoshape 2
"Morphs" are applied sequentially to the model and stored in a stack. You can move through the stack using the various undo and redo commands to morph and unmorph the model.
None.
