*ME_ModuleOccurrenceMoveContents
Move the contents from one module part to another.
*ME_ModuleOccurrenceMoveContents source_id target_id ?"option1=value1, option2=value2, ..., optionN=valueN"?
HyperMesh Tcl Modify Command
source_id
The ID of the source module part whose contents are being moved.
target_id
The ID of the target module part receiving the contents.
options (optional)
List of input options, passed as a comma separated string enclosed in quotes. Valid options are:
purge_target=<flag>
0 - Keep the original destination part contents alongside the moved contents.
1 - Default. Purge/delete the target module’s contents before starting the move operation.
Delete the contents in part 40, and then move the contents of part 30 to part 40:
*ME_ModuleOccurrenceMoveContents 30 40 "purge_target=1"
   # Handle error
Version History
14.0
