*updatefeatures
Specifies for element remesh with feature edges when 1D elements selected as features are also refined.
*updatefeatures flag
HyperMesh Tcl Modify Command
This command specifies for element remesh with feature edged when 1D elements selected as features are also refined.
This command implies a command that performs re-meshing/meshing by elements with redo option selected is to follow.
- flag
- 0 - 1D elements selected as feature edges are not refined (default).
To remesh elements 1-40 with element size 10, using 1D elements with IDs 100-110 as feature edges, and create along these feature edges new 1D elements with the same properties connected to created mesh:
*createmark elems 1 100-110
*elementsaddelemsfixed 1
*updatefeatures 1
*setusefeatures 1
*createmark elems 2 1-40
*defaultremeshelems 2 10.0 2 2 1 1 1 1 0 0 0 0 2 30
*setusefeatures 0
# Handle error
}Version History
12.0.110
