*geom_repair
Performs various repair operations on selected surfaces.
*geom_repair surf_mark=<mark_id> method=<value> ?width=<value>? ?optimize_geom=<value>?
HyperMesh Tcl Modify Command
- surf_mark=<mark_id>
- The ID of the mark containing the input surfaces. Valid values are 1 and 2.
- method=<value>
- The geometry repair method. Valid values are:
- width=<value>
- The maximum width of the gap that will be stitched. If no valid value is given, the model geometry cleanup tolerance is used as default value.
- optimize_geom=<value>
- Enable geometry optimization after the basic repair operation to match the new topology.
To stitch the gaps smaller than 0.2 between surfaces ID 51, 53 and 58 and optimize the geometry afterwards:
*createmark surfaces 1 51 53 58
*geom_repair surf_mark=1 method=sew_gaps width=0.2 optimize_geom=1
# Handle error
}Version History
2022.1
