*createmultiplespotwelds
Creates multiple spotwelds between a set of nodes on the finite element mesh for a given type of element, coordinate system, and property ID.
*createmultiplespotwelds nodecol1_markmask nodecol2_markmask tolerance length_given length systems movenode remesh configval ?property?
HyperMesh Tcl Modify Command
- nodecol1_markmask
- Independent node mark list.
- nodecol2_markmask
- Dependent node mark list.
- tolerance
- Search tolerance to pair the nodes.
- length_given
- Specifies if a length has been given.
- length
- Length of the spotweld element.
- systems
- Local coordinate system switch.
- 0 - Without coordinate system.
- 1 - With coordinate system.
- movenode
- Moves dependent node.
- remesh
- Remeshes dependent region.
- configval
- Element type configuration value.
- ?property?
- Name of property collector. Retrieves property ID.
Examples
*createmultiplespotwelds 1 2 0.05 0 0.0 1 1 1 61 "name_prop"
