*morphloadmvols
Loads morph volume, handle, and shape data from a file.
*morphloadmvols morphmvolfile nauto
HyperMesh Tcl Modify Command
- morphmvolfile
- Name of data file written using *morphsavemvols ().
- nauto
- 0 - Do not register all nodes found inside morph volumes
*morphloadmvols "mvols.dat" 1
This command will load all morph volumes, handles, and shapes in the specified file and load them into the model. Optionally, nodes in the model can be registered for the loaded morph volumes.
None.
