*morphmaprecalc
Recalculate influences and prepare for mapping.
*morphmaprecalc nlist nmark edgenode markedge facenode markface mode
HyperMesh Tcl Modify Command
- nlist
- List mark number for nodes affected by mapping.
- nmark
- 0 - Use input list 0
- edgenode
- NODES
- markedge
- Node mark number for nodes on edge domains where handles will be created.
- facenode
- NODES
- markface
- Node mark number for nodes on 2D domains where handles will be created.
- mode
- 0 - Create temporary handles and calculate new influences
*morphmaprecalc 0 0 NODES 2 NODES 3 0
This command is called before and after mapping operations in the user control sub-panel to enhance mapping speed. The command makes influence recalculation necessary only once, when entering the panel, rather than each time the user wishes to place a handle or edge.
# Handle error
