*maskentitymark
Masks the entities on the specified mark.
*maskentitymark entity_type mark_id flag
HyperMesh Tcl Modify Command
This command masks the entities of entity_type that are on mark_id. Valid mark_ids are 1 and 2. Only entities in displayed collectors may be masked.
To mask connectors and the realized FE, a flag of 1 must be passed. To mask only connectors (excluding realized FE) and all other entity types, a flag of zero must be passed.
- connectors
- points
- lines
- surfaces
- solids
- elements (both in components and groups)
- ellipsoids
- mbjoints
- mbplanes
- equations
- loads
- systems
- vectors
- tags
- handles
- domains
- symmetries
- morphconstraints
- comps (connectors, points, lines, surfaces, solids, elements)
- groups (main/secondary elements)
- loadcols (equations, loads)
- multibodies (ellipsoids, mbjoints, mbplanes)
- systcols (systems)
- vectorcols (vectors)
*createmark connectors 1 displayed
*maskentitymark connectors 1 1*createmark comps 1 all
*createmark elems 1 "by comps on mark" 1
*maskentitymark elems 1 0*createmark comps 1 all
*maskentitymark comps 1 0Errors
This command does not return any errors that can be handled.
