*morphshapeapplynodes
Applies the shapes on the mark to only the selected nodes.
*morphshapeapplynodes shtype shmark ntype nmark mult
HyperMesh Tcl Modify Command
- shtype
- Shapes
- shmark
- Shape mark number.
- ntype
- Nodes
- nmark
- Node mark number.
- mult
- Multiplier to applied shapes.
*morphshapeapplynodes SHAPES 1 NODES 1 2.0
Shapes on the mark are applied to the model consecutively and scaled up or down by the multiplier. Shapes will only be applied to the selected nodes.
None.
